Has anyone used LWIP with Processorexpert? I have attached an example, but it uses SPI for LWIP, may be helpful.
Original Attachment has been moved to: plc-stamp_1_examples-0.2-beta.zip
Thanks for the example. Unfortunatelly there are currently no plans for including support for LWIP into Processor Expert as a component.
However, it could be possible to add to application, like you did, and use Processor Expert Ethernet component.
Petr Hradsky
Processor Expert Support Team
