How to access u boot environment from linux?
Question asked by Alex Komar on Jul 3, 2013
Latest reply on Sep 12, 2013 by Yuri Muhin
Branched to a new discussion
Hello
I try to make firmware update tool for imx35. But i have one problem (
How can I access and change the u-Boot env variables in linux. Using the u-boot/tools/env directory in u boot directory:
u-boot$ make env
Which created the executable file fw_printenv. I copied this to /usr/sbin and on target etc/fw_env.config file:
# Configuration file for fw_(printenv/saveenv) utility. # Up to two entries are valid, in this case the redundand # environment sector is assumed present. # MTD device name Device offset Env. size Flash sector size /dev/mtd0 0x00000 0x20000 0x80000
target#./fw_printenv
What is causing this error?
Warning: Bad CRC, using default environment
bootcmd=bootp; setenv bootargs root=/dev/nfs nfsroot=${serverip}:${rootpath} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; bootm
bootdelay=5
baudrate=115200
target# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00080000 00020000 "Bootloader"
mtd1: 00300000 00020000 "nor.Kernel.1"
mtd2: 00300000 00020000 "nor.Kernel.2"
mtd3: 01c00000 00020000 "nor.rootfs.1"
mtd4: 01c00000 00020000 "nor.rootfs.2"
mtd5: 00003000 00020000 "FIS directory"
mtd6: 02001000 00020000 "Redboot config"
mtd7: 00300000 00080000 "nand.bootloader"
mtd8: 00500000 00080000 "nand.kernel"
mtd9: 10000000 00080000 "nand.rootfs"
mtd10: 00800000 00080000 "nand.configure"
mtd11: 6f000000 00080000 "nand.userfs"
