OS Awareness and MQX Lite
marcbunyard
What do I need to do to get OS awareness active with MQXLite?  I am using Code Warrior 10.4 Professional Edition with the K20D72M in the TWR-K20D72M, and have the MQXLite component in my project.  I don't know how to get the OS awareness working.  I don't see the OS Awareness Tab under Run->Debug Configurations->Debugger.  During debugging none of the MQX tools is functional.
ZhangJennie
see attached screenshot of where to enable OS awareness.
ZhangJennie
marcbunyard
The "OS Awareness" tab doesn't exist on the debugger tab.  I think something is wrong with my installation.  I started with the Special Suite and upgraded to professional.  Could that be blocking the "OS Awareness" tab?
anthony_huereca
I think that may be the case since I see the option and tried it out successfully on a K60 board. If you don't have a professional license installed properly, then the OS Awareness feature wouldn't available.
Also make sure you have any updates for it installed:
marcbunyard
Thank you Anthony.  I just tried the site, and it's down.  I'll try later.
Monica
Senior Contributor III
Hello Marc,
just checking up, did you get to try it once the site was up and running? Please keep us posted :smileywink:
Monica
marcbunyard
I am still unable to get the the site:
http://freescale.com/lgfiles/updates/Eclipse/MCU10_4/com.freescale.mcu.updatesite
I am working with an FAE, and still can't get my installation working correctly.  I'm not sure what the problem is.  Firewall?
ZhangJennie
if you can't access this link with online updating. please try to install updates via offline mode. here is the updates download link:
http://www.freescale.com/webapp/sps/site/overview.jsp?code=CW_UPDATES_MCU_10_4
here is the update procedure:
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/CW_MCU_SP_QS.pdf
marcbunyard
Thank you.  I did use the webapp site, and downloaded the updates.  Everything went according to the instructions, but I still don't see the "OS Awareness" tab.  I'm working with someone with the premise that it's a licensing issue.  We'll see.
marcbunyard
I finally uninstalled Both CodeWarrior and MQX 4.0, then re-installed them starting with CodeWarrior.  Now I have "OS Awareness".  It works for both MQX and MQX Lite.  I don't know what went wrong before, but I was trying to get the MQX 3.8 patch for The AR4100 WiFi board in, and I don't have to do that since it's already in.  So, I don't think I will be touching the environment for a while now.
