Kernel panic - not syncing: No init found.
vishvapathi
Contributor V
i am getting the below error, for testing purpose I download ready to use image from freescale web site and wrote into sd card memory ext2 partition which I created. I downloaded the Ubuntu Oneiric from freescale website.
Waiting for root device /dev/mmcblk1p1...
mmc2: new high speed SDHC card at address b368
mmcblk1: mmc2:b368 SDC   7.41 GiB
mmcblk1: p1
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk1p1): using internal journal
EXT3-fs (mmcblk1p1): recovery complete
EXT3-fs (mmcblk1p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:25.
Freeing init memory: 204K
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.t.
[<80047834>] (unwind_backtrace+0x0/0xf8) from [<80508af4>] (panic+0x74/0x18c)
[<80508af4>] (panic+0x74/0x18c) from [<80508808>] (init_post+0xa0/0xc4)
[<80508808>] (init_post+0xa0/0xc4) from [<800089b4>] (kernel_init+0x10c/0x13c)
[<800089b4>] (kernel_init+0x10c/0x13c) from [<80041aa4>] (kernel_thread_exit+0x0/0x8)
CPU2: stopping
[<80047834>] (unwind_backtrace+0x0/0xf8) from [<8003b324>] (do_IPI+0x150/0x17c)
[<8003b324>] (do_IPI+0x150/0x17c) from [<80040a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbffb5ef0 to 0xbffb5f38)
5ee0:                                     bffb5f38 0000000a 00000000 00000002
5f00: 00000282 bffb4000 bffb4000 00000000 80af77e0 00000002 80a90040 00000000
5f20: 80047134 bffb5f38 8007a570 80079fd4 20000113 ffffffff
[<80040a0c>] (__irq_svc+0x4c/0xe8) from [<80079fd4>] (__do_softirq+0x4c/0x140)
[<80079fd4>] (__do_softirq+0x4c/0x140) from [<8007a570>] (irq_exit+0x94/0x9c)
[<8007a570>] (irq_exit+0x94/0x9c) from [<8003b2e0>] (do_IPI+0x10c/0x17c)
[<8003b2e0>] (do_IPI+0x10c/0x17c) from [<80040a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbffb5f90 to 0xbffb5fd8)
5f80:                                     80af9140 80000093 00000001 00000000
5fa0: bffb4000 80af1ce4 80510fa4 80aa6e7c 1000406a 412fc09a 00000000 00000000
5fc0: 00000000 bffb5fd8 8004f648 80041b04 40000013 ffffffff
[<80040a0c>] (__irq_svc+0x4c/0xe8) from [<80041b04>] (default_idle+0x24/0x28)
[<80041b04>] (default_idle+0x24/0x28) from [<80041d08>] (cpu_idle+0xc8/0x108)
[<80041d08>] (cpu_idle+0xc8/0x108) from [<10505934>] (0x10505934)
CPU3: stopping
Exception stack(0xbff01f90 to 0xbff01fd8)
1f80:                                     80af9140 80000093 00000001 00000000
1fa0: bff00000 80af1ce4 80510fa4 80aa6e7c 1000406a 412fc09a 00000000 00000000
1fc0: 00000000 bff01fd8 8004f648 80041b04 40000013 ffffffff
CPU1: stopping
Exception stack(0xbffadf90 to 0xbffadfd8)
df80:                                     80af9140 60000093 00000001 00000000
dfa0: bffac000 80af1ce4 80510fa4 80aa6e7c 1000406a 412fc09a 00000000 00000000
dfc0: 00000000 bffadfd8 8004f648 80041b04 40000013 ffffffff
I checked the rootfs. It has /sbin/init, /etc/init files. I also tried pointing the init folder by setting environment, stil no difference.
How do i proceed. Any help would be appreciated.
Labels (2)
LeonardoSandova
Specialist I
Reformat your partition as EXT3 and place the rootfs again.
vishvapathi
Contributor V
I tried it already.. still the problem exists..... any other alternate for this!!!
LeonardoSandova
Specialist I
Make sure the kernel supports either ext2, ext3 or ext4. (on the kernel menu, go to file sytems submenu). I would also try with another SD card with at least 4GB.
vishvapathi
Contributor V
Hi Leo,
After adding "rootfstype=ext3" to env i am able to login. Though i am getting below message before login.
"No space left on device" but its a 8gb SD card.
Starting the hotplug events dispatcher udevd
udevd (1437): /proc/1437/oom_adj is deprecated, please use /proc/1437/oom_score.
Synthesizing initial hotplug events
Setting the hostname to freescale
Mounting filesystems
cp: writing `/mnt/rwfs/var/lib/rpm/Packages': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Filemd5s': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Provideversion': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Name': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Requirename': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Conflictname': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Sigmd5': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Group': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Dirnames': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Basenames': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Sha1header': No space left on device
cp: writing `/mnt/rwfs/var/state/dhcp/dhcpd.leases': No space left on device
cp: writing `/mnt/rwfs/var/state/dhcp/dhclient.leases': No space left on device
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
Starting the port mapper:
Starting the dropbear ssh server:
D-Bus per-session daemon address is: unix:abstract=/tmp/dbus-8evMBMKx7a,guid=269
gtk: creating gdk-pixbuf.loaders
pango: creating module list
starting pid 3278, tty '': '/etc/rc.d/rc_gpu.S'
starting pid 3286, tty '': '/etc/rc.d/rc_mxc.S'
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/freescale:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
arm-none-linux-gnueabi-gcc (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08)
root filesystem built on Tue, 02 Jul 2013 15:21:28 +0530
Freescale Semiconductor, Inc.
freescale login: (EE) XKB: Couldn't open rules file /usr/share/X11/xkb/rules/bae
(EE) XKB: No components provided for device Virtual core keyboard
unrecognised device identifier!
(EE) config/hal: NewInputDeviceRequest failed (2)
matchbox: keyboard does not appear to have a <alt> key.
matchbox: ignoring key shortcut <Alt>n=next
matchbox: ignoring key shortcut <Alt>p=prev
matchbox: ignoring key shortcut <Alt>c=close
matchbox: ignoring key shortcut <Alt>d=desktop
matchbox: ignoring key shortcut <Alt>m=!matchbox-remote -mbmenu
matchbox: ignoring key shortcut <ctrl><alt>x=!xterm
matchbox: ignoring key shortcut <ctrl><alt>r=!rxvt
matchbox: ignoring key shortcut <ctrl><alt>e=!!gpe-calender
matchbox: ignoring key shortcut <alt>Tab=next
matchbox: ignoring key shortcut <alt><shift>Tab=prev
matchbox: ignoring key shortcut <alt>space=taskmenu
matchbox: ignoring key shortcut <alt>escape=!matchbox-remote -mbmenu
matchbox: ignoring key shortcut <alt>f4=close
matchbox: Cant find a keycode for keysym 65480
matchbox: ignoring key shortcut f11=fullscreen
matchbox-desktop: loading /usr/lib/matchbox/desktop/tasks.so with args ( None )
matchbox-desktop: loading /usr/lib/matchbox/desktop/dotdesktop.so with args ( N)
user_overides is (nil)
mb-desktop-dotdesktop: failed to open /usr/local/share/applications
mb-desktop-dotdesktop: failed to open //.applications
mb-applet-menu-launcher: bonobo-browser.desktop has no icon, png or name
mb-applet-menu-launcher: failed to open /usr/local/share/applications
mb-applet-menu-launcher: failed to open //.applications
LeonardoSandova
Specialist I
For some reason, the /mnt/rwfs is not mounted. Try manually this
mount -t tmpfs rwfs /mnt/rwfs/
Also, there must be something not setting right on this file
/etc/rc.d/init.d/filesystems
vishvapathi
Contributor V
cat /etc/rc.d/init.d/filesystems
#!/bin/sh
if [ "$1" = "stop" ]
then
  echo Unmounting filesystems
  umount -a -r
  mount -o remount -r %root% /
  [ -x /sbin/swapoff ] && swapoff -a
fi
if [ "$1" = "start" ]
then
  echo Mounting filesystems
  if [ "$TMPFS" = "tmpfs" ]
  then
  mount -n -t $TMPFS shm /dev/shm
  fi
  if [ -n "$TMPFS" ]
  then
  mount -n -t $TMPFS rwfs /mnt/rwfs -o size=$TMPFS_SIZE
  fi
  if [ "$READONLY_FS" != "y" ]
  then
  mount -n -o remount -w %root% /
  NFSBOOT="`cat /proc/cmdline | grep -q /dev/nfs ; echo $?`"
  if [ "$NFSBOOT" == "0" -a -n "$RAMDIRS" ]
  then
  echo "Booted NFS, not relocating: $RAMDIRS"
  RAMDIRS=""
  fi
  else
  # initramfs, ramdisks, others? come up read/write by default
  mount -n -o remount -r %root% /
  RAMDIRS="$RAMDIRS /tmp /etc /var"
  fi
  if [ -n "$RAMDIRS" ]
  then
  for i in $RAMDIRS
  do
  if [ ! -e /mnt/rwfs/$i ]
  then
  cp -a $i /mnt/rwfs/
  mount -n -o bind /mnt/rwfs/$i $i
  fi
  done
  fi
  if [ -e /etc/mtab ]
  then
  rm -f /etc/mtab
  fi
  ln -s /proc/mounts /etc/mtab
  if [ ! -d /dev/pts ]
  then
  mkdir /dev/pts
  fi
  mount -a
fi
i tried to mount manually but still i get no space during booting...
ronglinchen
Hi Kaman
I have the same problem like "mb-applet-menu-launcher: failed to open //.applications   ",
Have you solved it?
Please tell me if you got it ,THX very much!!
