alsa-utils-1.0.27
Question asked by Sadasivam Balasubramanian on Jun 28, 2013
Latest reply on Jul 1, 2013 by Leonardo Sandoval Gonzalez
I am facing below errors while installing ltib, I have tried both options but still the issue is same.
kindly advice how to sort out this issue.
<br>
<br>
1st try
Processing: alsa-utils
Build path taken because: directory build, no prebuilt rpm,
Testing network connectivity
OK GPP:
Try alsa-utils-1.0.24.2-1355852159.patch.md5 from the GPP
http://bitshrine.org/gpp/alsa-utils-1.0.24.2-1355852159.patch.md5:
12:20:50 ERROR 404: Not Found.
Try alsa-utils-1.0.24.2-1355852159.patch from the GPP
http://bitshrine.org/gpp/alsa-utils-1.0.24.2-1355852159.patch:
12:20:51 ERROR 404: Not Found.
Can't get: alsa-utils-1.0.24.2-1355852159.patch at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
 main:572
Started: Fri Jun 28 12:20:40 2013
Ended:   Fri Jun 28 12:20:51 2013
Elapsed: 11 seconds
These packages failed to build:
alsa-utils
Build Failed
Exiting on error or interrupt
<br></p><p><span style="text-decoration: underline;"><span class="mce_paste_marker"><br></span></span></p><p><span style="text-decoration: underline; color: rgb(255, 0, 0);">2nd try</span><br></p><p>Processing: alsa-utils<br>========================<br>Build path taken because: directory build, no prebuilt rpm, <br>Testing network connectivity<br>OK GPP: <br></p><p><br></p><p>Try alsa-utils-1.0.27-no_xmlto-1.patch.md5 from the GPP<br>http://bitshrine.org/gpp/alsa-utils-1.0.27-no_xmlto-1.patch.md5:<br>12:33:37 ERROR 404: Not Found.<br>Try alsa-utils-1.0.27-no_xmlto-1.patch from the GPP<br>http://bitshrine.org/gpp/alsa-utils-1.0.27-no_xmlto-1.patch:<br>12:33:37 ERROR 404: Not Found.<br>Can't get: alsa-utils-1.0.27-no_xmlto-1.patch at ./ltib line 802.<br></p><p><br></p><p><br>f_buildrpms() returned an error, exiting<br>traceback:<br> main:572</p><p><br></p><p><br>Started: Fri Jun 28 12:33:32 2013<br>Ended:   Fri Jun 28 12:33:37 2013<br>Elapsed: 5 seconds</p><p><br></p><p>These packages failed to build:<br>alsa-utils </p><p><br></p><p>Build Failed<br></p><p><br></p><p>Exiting on error or interrupt<br></p><p><br></p><p>--
