Hi All,
I am trying to add Splash Screen image in IMX6 UBoot.
I have taken help from link
https://community.freescale.com/message/320514#320514
I am getting Splash Screen with 600x400 .bmp default file but I need to add splash Screen with 1280x800 resolution .
With 1280x800 .bmp, my uboot is hanged. I am using bin2txt.py to create .c file for this.
Any idea regarding this?
Solved! Go to Solution.
Try changing the resolution on the structure fb_videomode on the source code.
../ltib/rpm/BUILD/linux/arch/arm/mach-mx6/<the_name_of_your_board>.c
