Output to UART1 KL25Z
Question asked by gbd on Jun 27, 2013
Latest reply on Jan 23, 2014 by Gordon Jess
Hello everyone,
I'm trying to figure out how to get output from UART1 on my KL25Z. I'm using a bare metal platform and not CW. I've got a uart1_init() to configure the registers and everything looks to be correct but I'm not getting any output. This exact same init script will allow me to move uart0 around to the different uart0 pin locations. Any help you'd be willing to provide would be greatly appreciated
void uart1_init(int baud_rate)
    SIM_SCGC5 |= SIM_SCGC5_PORTC_MASK;
    // Turn on clock to UART1 module and select 48Mhz clock (FLL/PLL source)
    SIM_SCGC4 |= SIM_SCGC4_UART1_MASK;
    SIM_SOPT5 &= ~SIM_SOPT5_UART1TXSRC_MASK;
    SIM_SOPT5 |= SIM_SOPT5_UART1TXSRC(0);                 // FLL/PLL source
    // Select "Alt 3" usage to enable UART1 on pins
    PORTC_PCR3 = PORT_PCR_MUX(3);
    PORTC_PCR4 = PORT_PCR_MUX(3);
    UART1_C2 = 0;
    UART1_C1 = 0;
    UART1_C3 = 0;
    UART1_C4 = 0;
    UART1_S2 = 0;
    // Set the baud rate divisor
    #define OVER_SAMPLE 16
    uint16_t divisor = (CORE_CLOCK / OVER_SAMPLE) / baud_rate;
    UART1_C4 = UARTLP_C4_OSR(OVER_SAMPLE - 1);
    UART1_BDH = (divisor >> 8) & UARTLP_BDH_SBR_MASK;
    UART1_BDL = (divisor & UARTLP_BDL_SBR_MASK);
    // Initialize transmit and receive circular buffers
    buf_reset(tx_buffer1, BUFLEN);
    buf_reset(rx_buffer1, BUFLEN);
    // Enable the transmitter, receiver, and receive interrupts
    UART1_C2 = UARTLP_C2_RE_MASK | UARTLP_C2_TE_MASK;
    printf("UART1_C4 = %x \r\n", UART1_C4);
    printf("UART1_C2 = %x \r\n", UART1_C2);
    enable_irq(INT_UART1);
int uart1_write_err(char *p, int len)
    int i;
    __disable_irq();
    for(i=0; i<len; i++) {
        while((UART1_S1 & UART_S1_TDRE_MASK) == 0)  // Wait until transmit buffer empty
        UART1_D = *p++;                     // Send char
    __enable_irq();
    return len;
