recv() apparently ignoring part of a TCP Stream
Question asked by Clive Stokes on Jun 27, 2013
Latest reply on Dec 4, 2013 by Martin Latal
MQX 3.8 recv()
I have a requirement to read a file using TCP
My TCP Client does the following:
Creates a socket
Sets socket option: OPT_RECEIVE_NOWAIT TRUE
Binds client to socket
Connects socket to Host
Sends the string "Get /fs/title.htm HTTP/1.1\r\n\
Host: 172.18.11.137\r\n\r\n"
Uses the following code to retrieve the response:
#define MAX_SOCKET_WINDOWS_SIZE  1024 *
char sBuffer[MAX_SOCKET_WINDOWS_SIZE]={0};
_time_delay(30);
memset(sBuffer, 0, sizeof(sBuffer));
bytesReceived = recv(sockfd, sBuffer, 1024, 0);
printf("bytes received: %i\n",bytesReceived);
printf("Received \"%s\".\n",sBuffer);
while ((bytesReceived > 0) && (bytesReceived != RTCS_ERROR) )
      if (bytesReceived > 0)
Monitoring the transaction using Wireshark I get the following:
GET /fs/title.htm HTTP/1.1
Host: 172.18.11.137
HTTP/1.1 200 OK
Server: WindWeb/2.0
Connection: close
Content-Type: text/html
WWW-Authenticate: Basic realm="MPFR"
Content-Length: 2311
Date: MON JAN 21 16:00:00 2013
Last-Modified: MON JAN 21 16:00:00 2013
<<  the body of title.htm >>>
But my TCP Client only gives:
bytes received: 13
Received "HTTP/1.1 200 ".
bytes received: 0
The header and file from “OK” onwards seem to be ignored.
If  I change the HTTP command by sending the string: "HEAD /fs/title.htm HTTP/1.1\r\n\
I get on Wireshark:
Host: 172.18.11.137
HTTP/1.1 501 Not Implemented
Server: WindWeb/2.0
Connection: close
And from my client:
bytes received: 135
Received "HTTP/1.1 501 Not Implemented
Server: WindWeb/2.0
Connection: close
bytes received: -1
Received "".
Error recv() failed error code 1638
Which I would expect (presumably the server does not implement HEAD).
In both cases my server is responding as I would expect to the command sent but when using the GET command recv() does not capture all the data from the server.
