We found we cannot browse internet even we set the proxy in settings->wifi->modify network...
Then we found Freescale add a definition "FSL_ETHERNET_PROXY" to check the property "net.proxy" in external\chromium\net\proxy\proxy_config.cc.
Can we remove this definition for setting proxy on UI?
Any side effect if I remove it?
Why did you add this check of proxy?
Cliff
