I am using TWR-K60. I am able to run example project for ffs (mqx 4.0.1) . after power on reset, when I call fsopen, it always says "NOT A DOS DISK! You must format to continue.". how can I solve this problem.
Also after formatting, it says "Free disk space: 10723328 bytes", although I have 2Gb nand flash.
Thank you...
Solved! Go to Solution.
