Should I set all other GPIO to input mode before going to VLLS0?
Question asked by markosiponen on Jun 20, 2013
Latest reply on Jun 20, 2013 by Eduardo Viramontes Guerra
My application is going to use VLLS0 and wake up on a falling edge on PTD4/LLWU_P14.
AN4503 says the following:
Reduce pin loading of the MCU. When the MCU sources current through the output pins, the power is being
sourced through MCU_VDD. This is most evident when you output high frequency signals to an output pin as
you might with the FlexBus clock and address/data pins.
