RS485 on MQX 4.0 Port change
Question asked by yogesh patel on Jun 19, 2013
Latest reply on Aug 6, 2013 by Daniel Chai
I am a new to Tower system with codewarrior  and MQX. I have TWR-K20D72M and TWR-IND-IO. I am trying to use RS-485 port  From MQX example.
I want Know That If I want to change the UART Port in the example For example UART1 to UART2.
HOw can I do It . I dont understand On which port RS-485 is working .I am using the code below.
/**HEADER********************************************************************
* Copyright (c) 2008 Freescale Semiconductor;
* All Rights Reserved
* Copyright (c) 1989-2008 ARC International;
* THIS SOFTWARE IS PROVIDED BY FREESCALE "AS IS" AND ANY EXPRESSED OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL FREESCALE OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
* THE POSSIBILITY OF SUCH DAMAGE.
* $FileName: rs485.c$
* $Version : 3.8.4.0$
* $Date    : Oct-4-2011$
* Comments:
*   This file contains the source for the rs485 example program.
*END************************************************************************/
#include <mqx.h>
#include <bsp.h>
#include <fio.h>
#include <string.h>
#if ! BSPCFG_ENABLE_IO_SUBSYSTEM
#error This application requires BSPCFG_ENABLE_IO_SUBSYSTEM defined non-zero in user_config.h. Please recompile BSP with this option.
#endif
/* select if example transmit, or receive
** 1 transmit
** 0 receive
#define RS485_TRANSMIT  1
/* enable if device has RTS pin hw support */
#define HAS_485_HW_FLOW_CONTROL 1
/* set RS485 output device */
#define RS485_CHANNEL "ittyd:"
/* Task IDs */
#define RS485_TASK 5
extern void rs485_write_task(uint_32);
extern void rs485_read_task(uint_32);
const TASK_TEMPLATE_STRUCT  MQX_template_list[] =
   /* Task Index,   Function,         Stack,  Priority, Name,     Attributes,          Param, Time Slice */
#if (RS485_TRANSMIT == 1 )
   { RS485_TASK,   rs485_write_task,  1500,   8,        "rs_485", MQX_AUTO_START_TASK, 0,     0 },
#else
   { RS485_TASK,   rs485_read_task,   1500,   8,        "rs_485", MQX_AUTO_START_TASK, 0,     0 },
#endif
    { 0 }
/*TASK*-----------------------------------------------------
* Task Name    : rs485_write_task
* Comments     :
*    This task send data_buffer to rs485
*END*-----------------------------------------------------*/
      uint_32 initial_data
   MQX_FILE_PTR rs485_dev = NULL;
   char  data_buffer[] = "RS485 send example";
   boolean disable_rx = TRUE;
   uint_32 result;
   /* If mcu has hardware support for RTS pin drive (e.g. k60n512), open line with IO_SERIAL_HW_485_FLOW_CONTROL flag */
   #if (HAS_485_HW_FLOW_CONTROL)
   /* HW 485 flow control on chip*/
   rs485_dev = fopen( RS485_CHANNEL, (char const *)IO_SERIAL_HW_485_FLOW_CONTROL );
   #else
   /* HW 485 flow not available on chip */
   rs485_dev  = fopen( RS485_CHANNEL, NULL );
   #endif
   if( rs485_dev == NULL )
      /* device could not be opened */
      _task_block();
   /* half duplex, two wire. use only if disable receiver in transmit is desired */
   result = ioctl( rs485_dev, IO_IOCTL_SERIAL_DISABLE_RX, &disable_rx );
   if( result == IO_ERROR_INVALID_IOCTL_CMD )
      /* ioctl not supported, use newer MQX version */
      _task_block();
   #if !(HAS_485_HW_FLOW_CONTROL)
   /* User written function for flow control by GPIO pin - handle RTS other signal to drive RS485 HW driver */
   #endif
   /* write data */
   write( rs485_dev, data_buffer, strlen(data_buffer) );
   /* empty queue - not needed for polled mode */
   fflush( rs485_dev );
   /* wait for transfer complete flag */
   result = ioctl( rs485_dev, IO_IOCTL_SERIAL_WAIT_FOR_TC, NULL );
      _task_block();
   /* half duplex, two wire */
   /* if receiver was disabled before, enable receiver again */
   disable_rx = FALSE;
   ioctl( rs485_dev, IO_IOCTL_SERIAL_DISABLE_RX, &disable_rx ) ;
   #if !( HAS_485_HW_FLOW_CONTROL )
   /* User written function for flow control by GPIO pin - handle RTS */
   #endif
   _task_block();
* Task Name    : rs485_read_task
* Comments     :
   char  data_buffer[256];
      _task_block();
   /* wait for data */
   fread(data_buffer, 1, 18, rs485_dev);
   while(1)
    printf("\n - Buffer_DAta              = %s Hz", &data_buffer);
/* EOF */
Please Help
