Hi All,
I am trying FreeRTOS+Trace tool from Percepcio. I need to provide ram content of MCU to perform trace analysis.
Therefore I need to copy text content of memory window in CodeWarrior HiWave debugger to some text file.
Any method will do: copy-paste, export-import to file and so on...
So far had no success...
Anyone's got any idea?
Solved! Go to Solution.
you can perform save command in hiwave debugger. for example: SAVE 0x1000..0x2000 DUMP.SX thus the content from 0x1000 to 0x2000 will be saved to DUMP.SX file. Hope this helps!
