i'm working on CW with ethernet tap rev b on target p3041.
Solved! Go to Solution.
You should connect your broken etap to your computer using an usb wire. It's not very difficult to fix back the networks params - just let the etap boots up and use a serial terminal to write the inputs (the help command is all you need).
Marius
ok thanks,i used screen on /dev/ttyACM0.
Marius
