I used the IAR EWARM before. And now I want to switch to CW, but when I test it, I find the CW sometimes works, sometimes does not.
Is it true IAR is much more stable than CW?
Thanks.
Solved! Go to Solution.
Early versions of CW were less stable. However nowadays I would say stability is about the same for both, it depends what you are doing in there of course. :smileywink:
Pavel
Pavel
