I need to use RTC wakeup pin(L5) in K60FN1M0VMD12 chip. I couldn't find any support in MQX bsp for using this pin. I wonder if anyone knows how can I configure the chip to enable this pin? Do I need add something in rtc interrupt subroutine regarding this pin?
Cheers!
Solved! Go to Solution.
Dear amleng,
I'm sorry for delay replying, I just moved your post to this MQX community.
regarding to your issue, I suppose you want use the low power mode of K60 and then wakeup by RTC.
could you please refer to AN4447 which is available at:
https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MQX&fpsp=1&tab=Documentation_Tab
hope it helps!
Dear amleng,
hope it helps!
