Can not import K60N512 project.
danielchai
Senior Contributor I
Hi All,
I just installed the MQX3.8.1 patch for GS1500M. When I follow the instruction to import the project httpsrv_twrk60n512 from  rtcs\examples\gstwr_httpsrv. It gives me error:
Error processing changed links in project description file.
Details:
No file system is defined for scheme:
Any ideas about this?
Thanks.
danielchai
I found the problem.
The MQX_ROOT_DIR setting in the demo project is wrong.
The project is based on MQX3.8.1 but the MQX_ROOT_DIR is set to MQX3.7.
danielchai
