How to Change Default Clock Setting in Kinetis BSPs
Question asked by Colin Dawson on Jun 6, 2013
Latest reply on Oct 4, 2013 by Robert Slaymaker
I made a document with some print screens and it is attached.  The print screens don't paste.
Referring to the "How to Change Default Clock Setting in Kinetis BSPs" I completed this procedure summarized in the attachment called: Custom Clock
I basically end up with errors:
mingw32-make: *** [Peripheral IO Drivers/usb_dcc/int/usb_dcd_int_kn_c.obj] Error 1      bsp_Console_MK60FX512VLQ12                          C/C++ Problem
mingw32-make: *** [Peripheral IO Drivers/usb_dcc/polled/usb_dcd_pol_kn_c.obj] Error 1      bsp_Console_MK60FX512VLQ12                     C/C++ Problem
mingw32-make: *** [Peripheral IO Drivers/usb_dcc/usb_dcd_mk60_c.obj] Error 1      bsp_Console_MK60FX512VLQ12                          C/C++ Problem
mingw32-make: *** [Sources/Events_c.obj] Error 1                                          bsp_Console_MK60FX512VLQ12                     C/C++ Problem
I already opened a service request on this issue number: 1-1054023221
Unfortunately, they couldn't duplicate these errors doing exactly what I am doing.  I have tried this on two computers and get the same results.
My questions are:
Has anyone else seen this?
Is there a solution?
I think I must be doing something dumb when following the procedure.
The second attached document is what the service rep. sent me called:
