Working with FRDM board for some schools and upgraded to CW10,4. Searched through all sections I/class can find to no avail.
Solved! Go to Solution.
Hi William,
is your question about how to create S-Records?
Then it is this: S-Record Generation with gcc for ARM/Kinetis | MCU on Eclipse
I hope this helps.
Hi William,
I hope this helps.
Erich,
The class thanks you. I see we use the .hex since it doesn't generate an actual .S19 file.
Thanks again.
if you configure the output format to s-rec, then the .hex file contains an S-Record/S19 content.
It is odd that ARM Inc. has not set up the Eclipse panel that it changes the output extension.
So even if it has .hex extension, it contains the correct content.
I hope this helps.
