problem of program running on flash( interrupts)
Question asked by FU grace on Jun 3, 2013
Latest reply on Jul 1, 2013 by FU grace
Hi everyone,
I have solved the e2448 problem on my program without interrupt service routine.But when I apply it on other program with interrupt service,then comes problem.
It jumps to default handler() function.But actually the program works well on RAM.So I really don't know what's the problem.When I step into each line,I found the  problem occurs at the "EnableInterrupts;" which is defined by:  #define EnableInterrupts asm(" CPSIE i");
I'm using K60,CW10.3 ,GCC compiler.
Can anyone give me some hints?Thanks a lot!
Grace
