I am trying to test some module on sabrelite board.
because of the size issue I have to use small fs so I use compact buildroot fs.
I found unit_tests source file but can't find correct driver to use unit_tests app.
for example, to test mxc_i2c_test
32 i2c_file = open("/dev/mxc_test", O_RDWR);
33 if (i2c_file < 0) {
34 printf("Open failed\n");
35 exit(-1);
36 }
37
38 /* Enable the CSI clock */
39 ioctl(i2c_file, MXCTEST_I2C_CSICLKENB, &i2c_test);
where can I find these information of /dev/mxc_test or MXCTEST_I2C_CSICLKENB ... and so on ..
silee
