I have a problem with programming the CFV1 Controller MCF51EM. In my testapplication for programming the controller in our production a new or unprogrammend controller needs an Power down/off of the controller. As this is not realised in the testapplication I want to ask if someone know if there is a posibility in the settings to solve this that no power down/off is needed?
Best regard
Sezgin
Hi Sezgin,
Unfortunately the only guaranteed way to get a a MCF51 into BKGD mode is through a power-cycle with the BKGD pin low. This is described in the device manual.
Often it is not necessary - but in many cases for blank device it will be.
This is independent of the programmer used. Some programmers provide the ability to cycle the power when required.
bye
