LTIB building error
LTIB building error
andreyvarsegov
Hi all,
I want to make gst at my rootfs, but get error:
Processing: libfslcodec
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try libfslcodec-3.0.6.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/libfslcodec-3.0.6.tar.gz.md5:
20:14:54 ERROR 404: Not Found.
Try libfslcodec-3.0.6.tar.gz from the GPP
http://bitshrine.org/gpp/libfslcodec-3.0.6.tar.gz:
20:14:55 ERROR 404: Not Found.
Can't get: libfslcodec-3.0.6.tar.gz at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
main:572
Where i can find libfslcodec-3.0.6.tar.gz.md5  and libfslcodec-3.0.6.tar.gz files?
Best regards, Andrey.
Yuri
LeonardoSandova
Specialist I
Hi Andrey,
they are in a separate tarball on the freescale portal. Once you have them, untar the file under /var/tmp/pkgs (I am not 100% of the pathname but check the documentation please) and compile again (meaning, run ltib again)
Leo
