Hello
Not sure which version of CodeWarrior you are using and which CPU you are targeting.
Anyway it looks like a Code Completion window popping up.
Can you try the following:
- Start the IDE
- Select Edit -> "Preferences"
- Switch to Code Completion" panel in "Editor" tree
- Uncheck all boxes in that panel.
- Close the IDE Preferences dialog clicking on OK
Does that solve the problem?
CrasyCat
