Unexpected boot behavior on i.MX6SL EVK
Question asked by Kathy Wright on May 17, 2013
Latest reply on Jun 6, 2013 by Kathy Wright
I'm using the i.MX6SL EVK and I have the SD card in SD1.  I'm seeing that it boots from the SD card even when I have the BOOT MODE switches set for Serial Download.  I've checked that the fuses are not blown (especially BT_FUSE_SEL), though that shouldn't matter.  The only way I can make it enter serial download mode is to remove the SD card and then reset/POR.
This does not happen with SD3.
What would make it boot from SD (internal boot) when I've set BOOT MODE for serial download?
