IMX51 WEIM & Numonyx M29EW NOR Flash
wysockilukasz
I'm trying to develop communication with the Numonyx flash
I have a problem with one of the WEIM  (Wireless External Interface Module) register -> CS0GCR1.
I can't set up one of it's bit-> number 7 (it's sey that connectet memory is not PSRAM),
this bit isn't hardware dependent but it's allways 0 no matter whot I write.
Can anyone can help my?
Lukas
wysockilukasz
Problem solved,
there is a error in documentation - offset of the WEIM (CS0GCR1 and others) registers is 0x2000 (not 0x2020).
Lukas
wysockilukasz
Problem solved,
Lukas
