nand_flash mqx demo doesn't work on K70
Question asked by Lorenzo Fornari on May 14, 2013
Latest reply on Jun 18, 2013 by Lorenzo Fornari
Hello, i've tried the nand_flash demo, provided in "example" folder in mqx 4.0.
The demo works properly only if you don't generate processor expert code.
Whether PE code is generated, the application finds bad all blocks, and cannot write or read correclty from them.
Simply deleting generated code and rebuilding bsp, makes the demo working properly again.
I've deleted all components in PE configuration, leaving only mqx and cpu,with the same result.
I think there are some conflicts, but i haven't yet found where...
Some ideas?
