Unable to boot latest Android i.MX 6 Q SABRE Platform image
dougschwanke
I downloaded the latest image IMX6_DQ_SDP_SD_DEMO_IMAGE (MX6Q-SDP-Android_r13.4.1.exe).
Since there are no install instructions, I just ran the executable on my WINXP system.  After
burning the images onto a 16G SD card, I plugged the card into my platform and applied power.  The image
does not boot and I do not see any UART activity.  Plugging in the original SD card that came with our system works.
-  Is there anything I need to know about prior to running the EXE such as format?
-  Are there any limitations as to what type of card I can use to boot with (8G, HC, SANDISK-only)?
Labels (2)
Tags (2)
dougschwanke
It turns out I was pointing to the logical drive and not the physical drive of my SD card.  Selecting the physical driver fixed my issue.
dougschwanke
