Hi all,
I display the vedio with HDMI out to TV,At the beginning of the sounds and images are correct, but after about 8 minutes, the TV image without (black), voice and. To plug the HDMI cable, fault can not be restored, what is wrong?
Solved! Go to Solution.
Hello,andypeng,
It seems that system entered into sleep status. You can try to press power button to wake it up !
Weidong
Hello,andypeng,
Weidong
Weidong Sun 撰写:
Hello,andypeng,
Weidong
Hi Weidong,
Thank you for your reply.I can wake it up when i press the SW4–Volume Up Button,not SW1–Optional Power Button on
SABRE Board imx6Q.
I want to disable the function when i player vedio , could tell me How to modify the driver?
