How set mx6q_sabresd output the display data to YUV format
kaisun1
HI :
      we use ms6q_sabresd board as a platform to development .  we need the board output the display data  format is 20-bit YCbCr .
Then i read kernel and uboot code .and only find the code what is support HDMI LVDS and RGB  format . what i shoud do ?
Thanks anyway!
ChucoChe
Please check the Linux Release notes table 6. the video section. If the format you want doesn't works in setting by kernel boot parameter. I'm afraid you will have to add it in the kernel or driver.
Michel
ChucoChe
Michel
kaisun1
Hi michel:
              this proble i have resolve. imx6 is support it .
kaisun1
HI ,This problem has been solved.   now  i  can output 720P video data.  but 720i  is not work.
