i.MX53-QSB-Android-Gingerbread make android filesystem error
WeiWeiBo
Hi All:
When I make the I.mx53-QSB android filesystem, show the error massage as below attached file after I use the command
" $ ./build_android.sh --board=imx53_qsb --build-choice=android --lunchtype=eng "
how can I use something patch or method to solve this problem?
thxs
target Non-prelinked: libsqlite_jni (out/target/product/imx53_loco/symbols/system/lib/libsqlite_jni.so)
Install: out/target/product/imx53_loco/system/lib/libsqlite_jni.so
Install: out/target/product/imx53_loco/system/lib/libsrec_jni.so
target Prebuilt: libstagefrighthw (out/target/product/imx53_loco/obj/lib/libstagefrighthw.so)
true
Install: out/target/product/imx53_loco/system/lib/libterm.so
Install: out/target/product/imx53_loco/system/lib/libthread_db.so
Install: out/target/product/imx53_loco/system/lib/libttspico.so
Install: out/target/product/imx53_loco/system/lib/libttssynthproxy.so
target SharedLib: libwebcore (out/target/product/imx53_loco/obj/SHARED_LIBRARIES/libwebcore_intermediates/LINKED/libwebcore.so)
collect2: ld terminated with signal 7 [Bus error]
make: *** [out/target/product/imx53_loco/obj/SHARED_LIBRARIES/libwebcore_intermediates/LINKED/libwebcore.so] Error 1
/home/victor/i.MX53-QSB-Android-Gingerbread-Release4.2
mkimage: Can't open ./ramdisk.img: No such file or directory
Labels (2)
charleschang
The memory (swap) of your building machine is not enough ?
weidong_sun
Hi,Lan,
    It seems that you should install some neccesary packages, please check them :
(1)installing package in ubuntu host
#sudo apt-get install git-core
#sudo apt-get install gnupg
#sudo apt-get install flex
#sudo apt-get install bison
#sudo apt-get install gperf
#sudo apt-get install libsdl-dev
#sudo apt-get install libesd0-dev
#sudo apt-get install libwxgtk2.6-dev
#sudo apt-get install build-essential
#sudo apt-get install zip
#sudo apt-get install curl
#sudo apt-get install libncurses5-dev
#sudo apt-get install zlib1g-dev
#sudo apt-get install python2.5
(2)Installing java6-jdk
There is a PPA (Personal Package Archives) made available by Roberto Ferramosca.  (https://launchpad.net/~ferramroberto/+archive/java)
To add this PPA  (as root) and install the JDK, run the following:
$ sudo apt-get install python-software-properties
$ sudo bash
# add-apt-repository ppa:ferramroberto/java
# apt-get update
# apt-get install sun-java6-jdk sun-java6-plugin
# exit
Weidong
