TWR-PXS20 FlexCAN
Question asked by Jiri Takac on Apr 29, 2013
Latest reply on Apr 29, 2013 by Martin Latal
I'm using MQX 3.8 and I'm trying to understand a configure FlexCAN.
So my problem is when I use parameter "FLEXCAN_MESSAGE_TRANSMIT_ONCE" in function "FLEXCAN_Activate_mailbox".
Which, according to MQXIOUG, should transfare message only once when i use "FLEXCAN_Tx_mailbox" or "FLEXCAN_Tx_message".
But the procesor is transmitting message continuously and stop transmiting only after deactivating the mailbox.
I noticed that in file flexcan_regs.h is this parameter as macro, but it has the same value as "FLEXCAN_MESSAGE_TRANSMIT_REMOTE".
So question is, what I am doing wrong and if you can help with this problem.
Thank Jiri
