Does the i.MX28 Windows CE 6.0 BSP Support SD Hive Registry?
markwilliams
Senior Contributor I
Hi all,
Does the i.MX28 Windows CE 6.0 BSP support having the registry hive on the SD card? I noticed a question regarding this on another i.MX device and a response from Adeneo was that it was not supported for SD, just for NAND.
I was wondering if the i.MX28 BSP will allow the use of an SD registry? If so has anyone implemented this and could give me some pointers?
I have read the Microsoft documentation but was wondering if there is anything specific in the BSP I should watch out for.
Kind regards, Mark
Labels (2)
karina_valencia
NXP Apps Support
NXP Apps Support
Deactivated user are you available to help on this  case?
karina_valencia
NXP Apps Support
NXP Apps Support
Adeneo Engineering Team can you confirm if you are available to help on this  case?
