chiasyan
Issue for "Init_UART" Code Generation by PE
Discussion created by chiasyan on Apr 26, 2013
Latest reply on Apr 29, 2013 by Vojtech Filip
There has been an issue for "Init_UART" (Low Level Peripheral Initialization) code generation by PE.
Based on the Reference Manual (Kinetis K20, Chapter 47, pg.1208), UARTx_BDH should be initialized prior to UARTx_BDL, but PE perform otherwise.
Thank you.
