How to build the OpenVG 0.4.0 src libraries for Vybrid
Question asked by Ioseph Martinez Pelayo Employee on Apr 24, 2013
Latest reply on May 10, 2013 by Jim Mikola
As you may already realized, the source code release does not have the necessary makefiles to re-build the libraries. If you need to make some changes, say on the DCU/OpenVG glue logic drivers, add support to a different display or use something else you will need to rebuild them.
You need to follow the next steps to patch you release and being able to rebuild the drivers:
1. unzip attached file
2. cp -a makefile4lib/* $release_install_dir/vf600_ovg
3. change hal/inc/gc_hal_types.h, define _DBG_EXIT_ to be empty
4. cd tests/rotation_800/build-autovf600-gnu-mqx-d
5. make cleansub allsub MQX_LOC=/media/shared/MQX402EAR1OVG040/lib/vybrid_autoevb_a5.gcc_cs
