Hi there!
I use the MMPF0100 to supply an i.MX6 application.
Not all of the SMPS are necessary in my application.
The idea is to disable the unused SMPS (OTP - MMPF0100) and to connect all unused pins to GND.
Is this necessary/possible/usual?
Thanks for help.
Kind regards
Peter
Solved! Go to Solution.
Hi Peter,
Unused switching regulators should be connected as follows: Pins SWxLX and SWxFB should be unconnected and pin SWxIN should be connected to VIN with a 0.1uF bypass capacitor.
Best regards.
Jorge.
Hi Peter,
Best regards.
Jorge.
Many thanks to you.
Kind regards
Peter
