Command line Build
Command line Build
DiamarTech
Hi!
I´m interesting to use Codewarrior command line builder, but I don´t know how i can use it. I am using CodeWarrior v5.9 IDE for HCS12 V4.7 and I don´t find where is the command line executable.
can Anyone help me, please?
Thank you.
BlackNight
Hi David,
have a look here:
C:\Freescale\CWS12v5.1\Help\PDF\
Build_Tools_Utilities.pdf
Compiler_HC12.pdf
Assembler_HC12.pdf
I hope this helps.
BlackNight
Hi David,
you mean building with make files or batch files?
Yes, you can run the compiler/linker/etc in command line mode too.
E.g. you can run the compiler from the DOS shell with
prog\piper.exe chc12.exe foo.c
Apart of that, you need to set up a batch file or a make file.
How to use make files, here is a background article (Make my Make with Eclipse and MCU10 | MCU on Eclipse). It is using Eclipse, but the same principles apply for your classic CodeWarrior.
I hope this helps.
DiamarTech
Hi Erich!
First, Thank you very much for your quick answer. Exacty, I want to build my program with make files. Where Can I get a manual file about piper and other codewarriors command line tools? For example, linkers, compilers information flags and so on.
Thank you, very much.
David.
BlackNight
Hi David,
have a look here:
Compiler_HC12.pdf
Assembler_HC12.pdf
I hope this helps.
DiamarTech
Hi Erich!
Thank you very much.
