I need to run about 70KB of code faster. I think that running it in ram could increase the speed enough.
The software size is too big to run all in ram so I need to use some code in flash and other in ram.
Some routines in ram have to call some routines in flash and vice versa.
Please is there a sample code that can load an executable library in ram at than calling routines (with codewarrior, micro k60)?
Thank you
Alberto
