Hi, this is my first IMX design at all and I'm a bit lost with all this reference manuals / schematics / datasheets.
The Ethernet Phy we've selected is Micrel KSZ9021RN, so I have to connect NVCC_RGMII to 2.5V source ( I found a helpful hint here in the forum).
To avoid the DC level shifter on ENET_REF_CLK (reference schematic: 2x68k + 1uF) I would like to know if it's possible to supply NVCC_ENET with 2.5V too.
Michael
Solved! Go to Solution.
Hello,Michael,
from datasheet of i.mx6dq:
you can use 2.5V to NVCC_ENET module. Please notice : VDDIO between ENET and Phy should be 2.5V.
Weidong
Michael, please click Correct Answer if your question has been answered, so that we can close the DI.
Yixing
Hello,Michael,
Weidong
