Anthony Huereca
DS-5 License Issue Solution
Discussion created by Anthony Huereca Employee on Apr 17, 2013
Latest reply on Apr 22, 2013 by Anthony Huereca
We've had various people have issues occasionally with compiling projects in DS-5 with the following error:
Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201301
System clock has been set back
Usually building again would clear the error. The reason this occurs is because DS-5 detected some files on your computer that are dated ahead of the current time. They have a utility available to scan for those files if you contact their support, and then there are a multitude of different ways to update timestamps on the files it finds.
In our experience, IAR has several files like these in the <IAR install dir>\common\ folder, so check there first and that may solve the problem.
