Flexbus differences on MK60FN1M0VMD12 and MK60DN512VMD10
OliverSedlacek
I've got hardware and software for my MK60DN512VMD10 to drive the Flexbus successfully, but after swapping the processor to an MK60FN1M0VMD12 the Flexbus doesn't work. I still get a 50MHz Flexbus clock, but I can't detect any bus cycles, i.e. FB_CS1 now shows no activity. Does anyone know what differences between the processors I may have overlooked?
Hui_Ma
There with the Flexbus memory map definition difference.
Please check below memory map table for MK60DN512VMD10 and MK60FN1M0VMD12.
Wish it helps.
Hui_Ma
Wish it helps.
OliverSedlacek
Changing to 0xA000 means I get FB_CS1 activity!
OliverSedlacek
Thanks, it looks like it helps. I had been using addresses in the 0x7000 range, so I will try 0x6800 or 0xA000 and see if that works.
