having K60 tower with TWR SER need source code to check the serial to Ethernet bridge conversion for one of the application , is it available if so please chare it
there will be new Ethernet to serial demo in the MQX 4.0.2. This version is not released yet, but I can give you source code of this demo (it is in attached zip). It should work on all platforms (including K60). There is also readme PDF which you can use as guide for setting this application up.
Karel Mozny
Hi karel,
thanks for sharing the code will check
