Messaging between tasks in MQX...
c_dawg
Declaring CW 10.3 and MQX 3.8.1...
I successfully sent a private message from one task to another.  I’m curious if it possible to set up another private message pool to send a message back or must you go to a system message format?  Are multiple private messages allowed?  I attempted to set up a second private message pool and it can’t allocate a message to it.  Any suggestions?
Luis_Garabo
Hi Colin,
You should be able to do so. We provide a simple example that does similar thing:
C:\Program Files\Freescale\Freescale MQX 3.8\mqx\examples\lwmsgq
There are two messages queqes One for the server and another for the clientes. Take a look to that example. I hope that helps you.
-Garabo
