How do I flash .out or .afx files?
anguel
Contributor V
Hi!
I found some precompiled demos for the TWR-K70F120M and the TWR-LCD-RGB here:
TWR-LCD-RGB Product Summary Page
These are .out files (from IAR) and .afx files (form CodeWarrior). I wonder if I can flash those files with the free versions of those IDEs or with some other tools to be able to see the demos?
Anguel
Tags (3)
BlackNight
There are several way to flash files of any size with CodeWarrior:
Using command line tools:
Standalone Flash Programmer | MCU on Eclipse
Using the 'Flash' button:
Flashing with a Button | MCU on Eclipse
BlackNight
anguel
Contributor V
Erich,
Thank you. I will try this as soon as I have the hardware.
Actually I looked at the flash tool in CodeWarrior but was confused because it asked for some flash configuration file and I only have a single .afx file in the demos.
Anguel
anguel
Contributor V
Thank you once again Erich!
I tried your second tutorial and it worked fine.
Anguel
