I have a project created by using the Device Initialization. I would like to add the USB CDC Virtual Com Port example code into the existing project. Can anyone tell me how to do it? I am new in this area and this CodeWarrior development tool. The USB CDC Virtual Com Port example code comes from Freescale USB Stack v4.0.3.
Thanks!
Paul
I'm not using Device Initialization, but using the Init component in combination with the FSL USB Stack 4.0.3.
This might be a starting point for you.
How this looks like is described in Tutorial: USB CDC with the KL25Z Freedom Board | MCU on Eclipse
It supports right now KL25Z, ColdFire JM16/JM60/JM128/52259
Examples and the Processor Expert component code can be found on GitHub:
mcuoneclipse/Examples at master · GitHub
Hope this helps.
Thanks Erich for the information, but my existing project was not created by the Processor Expert.
