Linux_Multimedia_Framework_User_Guide.pdf(imx6 )
Question asked by andypeng on Mar 31, 2013
Latest reply on Apr 4, 2013 by Yuri Muhin
Hi all,
  Linux_Multimedia_Framework_User_Guide.pdf.
  Installing/Building the Plugins on Ubuntu
1.1.4  Installing/Building the Plugins
2.  Install BSP support libraries package, the package is released with BSP. (you need to
have the .deb file available to the board, a USB-Key or copying the file to the board in
some other way should be fine)
sudo dpkg -i imx-lib-$VERSION-$RELEASE.deb
sudo dpkg -i kernel_$VERSION-imx_$RELEASE_armel.deb
It is desired to install all other BSP Debian packages.
where is the packages that is released with BSP?I can't find any *.ded file in BSP.
Can anybody answer this question ?
