libfsl-mm-core1_1.9.5-2_armel.deb cannot find some .so in libgst-fsl-mm-plugins_1.9.5-1_armel.deb
zhiyancao
In i.MX51 ubuntu10.04, I install libfsl-mm-core1_1.9.5-2_armel.deb and libgst-fsl-mm-plugins_1.9.5-1_armel.deb,
through run gst-inspect-0.10 -b,
I found some .so in blacklist.
Through run gst-inspect-0.10  /usr/lib/gstreamer-0.10/libmfw_gst_mp3enc.so
Tips:
Open module failed: lib_mp3_enc_arm12_elinux.so not find.
How to solve the problem?
yossishukron
can you explain your problem in more details .
what are you trying to do what modules did you install ?
