Is it possible that ADC's all channel(0~15) for k40 use in sequencial conversion mode using a PDB block ?
Question asked by brandonk on Mar 25, 2013
Latest reply on Jun 21, 2013 by Santiago_Lopez
HI Everyone
I am writing to inquire the below my K40 ADC Issue.
Is it possible that ADC's all channel(0~15) for k40 use in sequencial conversion mode using a PDB block.
I would explain my intended case in using adc with pdb block which is trigger.
In ADC0,
A channel 0 is started converting by PDB's trigger, If channel 0 is finished conversion,
The next channel 1 is started converting by PDB's trigger, If channel 1 is finished conversion,
The next channel 2 ~
The last channel 15 is started converting by PDB's trigger, If channel 15 is finished conversion
The upper works are repeated in same way.
I have been studing the related application note and K40 reference menual.
Please advice me this
Thank you
