LTIB build problem at package pkgconfig for Freescale M54418
Question asked by Francois Bouchard on Mar 22, 2013
Latest reply on Mar 25, 2013 by Francois Bouchard
Ltib build is failing at package pkgconfig,
MESSAGE:
checking for a BSD-compatible install... /usr/bin/install -c
checking for extra flags to get ANSI library prototypes... configure: error: cannot run test program while cross compiling
See `config.log' for more details.
configure: error: /bin/bash './configure' failed for glib-1.2.8
error: Bad exit status from /home/fbouchard/ltib/ltib-modelo-20100709/tmp/rpm-tmp.91454 (%build)
RPM build errors:
Build time for pkgconfig: 14 seconds
Failed building pkgconfig
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Fri Mar 22 16:58:16 2013
Ended:   Fri Mar 22 16:59:16 2013
Elapsed: 60 seconds
These packages failed to build:
pkgconfig
Build Failed
Exiting on error or interrupt
Now in a post I saw if I understand correctly, this package isn't meant for the Coldfire processors
--> http://comments.gmane.org/gmane.comp.package-management.pkg-config/342
Enrico> The bundled glib-1.2.10 is not crosscompile'able.
Enrico> Look at glib-1.2.10/configure.ac: once you use AC_TRY_RUN, your
Enrico> package cannot crosscompile. A very common standard error in
Enrico> autoconf-based packages ...
But if you build with an external libglib (--with-installed-glib) it
builds without problems.
- tried in pkconfig.spec (made backup of the original)
I tried the trick above but it didn't work.
Any hints on how to compile pkgconfig?
Francois
