freescale provide some *.deb, for example libfsl-mm-core1_1.9.5-2_armel.deb etc, but these debs is for ubuntu1004, I want to use ubuntu1210 as my system, how to use these debs, direct dpkg -i, is right? who can give some suggestions.
Solved! Go to Solution.
The latest ubuntu supported by FSL is oneric Ubuntu 11.10. I guess you could try by installing the libraries manually and then trying to fix the dependencies. Keep a backup of your system if you try that.
Michel
Michel
